OK..
First off your fridge cools using the 120V AC electric element. That is good cause it means cooling unit works
Now for the propane side.....you can get flame using butane torch.
So thermocouple works, gas flows...all good
NO 12V DC at terminal block. That 12V DC power source comes from your DC Dist. Panel and should be feed thru a 20A fuse.
Need to locate DC fuses, ID one for fridge circuit and get DC voltage to fridge terminal block
With good 12V DC Voltage
Turn Selector knob to 'GAS'----Lamp on far left should now come ON
Turn Gas Thermostat Knob 1/4 turn from OFF position
Press 'button' fully IN and HOLD (thermo safety valve)
When Lamp goes OFF.continue holding button in for at least 15 seconds more----then release button.
IF Lamp comes back ON------REPEAT (Lamp should stay OFF
Thermocouple tip needs to be over 2 of the burner slots and engulfed in main flame
Thermostat control (Fridge ON)
OFF-----burner runs continuously at bypass rate (just enough to stay lit)
MAX-----burner runs continuously at full gas rate
Any position in between-------burner cycles between full flow to bypass flow based on temp in food section
Operate fridge LEVEL.
Good luck!
