โJun-10-2020 03:30 PM
โJun-11-2020 07:02 AM
enblethen wrote:
No, you would not need to do anything else except replace element. It is just a double check that is the problem.
โJun-11-2020 05:28 AM
Bud
USAF Retired
Pace Arrow
โJun-11-2020 04:11 AM
enblethen wrote:
Yes, but check with Ohm meter for continuity between ground and the leads. Commonly, the element goes to ground where it enters the stack.
โJun-10-2020 08:07 PM
Bud
USAF Retired
Pace Arrow
โJun-10-2020 07:21 PM
โJun-10-2020 06:23 PM
Bud
USAF Retired
Pace Arrow
โJun-10-2020 06:16 PM
enblethen wrote:
Did you use an Ohm meter to check element to ground?
Relay on circuit board could be problem. You could pull circuit board. If relay is the issue there will be burnt area on back of board.
Resistance is not that far off. That much variation could be in different meters.
If you change out circuit board, I recommend a Dinosaur Electronics version.
Problem is between the 120 volt fuse and the element not in cord.
โJun-10-2020 06:08 PM
Bud
USAF Retired
Pace Arrow
โJun-10-2020 05:23 PM
โJun-10-2020 04:47 PM
โJun-10-2020 04:19 PM
itsjustjer wrote:
Just to update: I checked the heating element and itโs 37.4 ohms. The spec in the manual says 44. Am I likely too far out of spec?
โJun-10-2020 03:57 PM
โJun-10-2020 03:55 PM
