Dometic side by side refrigerator interior light out
tvfrfireman
I noticed the light was out in our one year old Dometic side by side refrigerator. I removed the bulb only to find a lot of yellow/brown melted plastic behind the bulb cover. Looks pretty bad. Has anyone else had this problem? We have used it very little as the new trailer is in the shop a lot.
2 REPLIES 2
larry_barnhart
the switch in the door frame might have been hit and this will keep the light on. Easy to find out after the new bulb is installed. manually turn the light off and it does not go out that is the problem.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
eHoefler
Sound like the light never shut off.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
