โMar-27-2015 05:58 PM
โMar-29-2015 05:32 PM
Dtank wrote:myredracer wrote:
We have a 30 amp TT and if I ever just had to have more power, like say for a 2nd AC,
I'd install a 20 amp power inlet on the side of our TT and run a 20 amp extension cord to the 15/20 amp recept. on a pedestal.
Like this poster did ??
โMar-29-2015 10:59 AM
โMar-29-2015 10:54 AM
LarryJM wrote:
I did this mod in lieu of converting my trailer to a true 50A service feed because of the cost of conversion
and not wanting to wrestle that 50A Anaconda cord in colder weather.
โMar-29-2015 10:15 AM
โMar-29-2015 08:57 AM
joebedford wrote:Golden_HVAC wrote:I have NEVER seen a 30A or 50A GFI receptacle. 15A and 20A yes, but that's not what OP is talking about.
modern RV parks use GFI receptacles
This adapter might work for me: I have two 30A plugs on my garage for when friends come to visit. When my RV is there alone, I could plug my RV 50A plug into the adapter and have twice the power than with my dogbone adapter.
โMar-29-2015 08:50 AM
westernrvparkowner wrote:Perhaps you missed the post that he's added a second 30A circuit to his rig for more power which of course no RV mfg would ever do. Better to convert his rig to 50A.
Whatever that Rube Goldberg contraption is doesn't look any easier than just using the cord your rig was designed with.
โMar-29-2015 08:22 AM
LarryJM wrote:Whatever that Rube Goldberg contraption is doesn't look any easier than just using the cord your rig was designed with. Frankly it looks like Medusa's head of snakes. And what is the chain for, other than to create a spot where it can wear through the cable sheathing and deliver a nasty shock to the unaware?Redterpos3 wrote:
Was doing some "window" shopping on Camping World site, and saw a dogbone for dual 30 amp to a single 50 amp receptacle. Are there actually RV's that have 2 30 amp hookups??
Well I'm sort of confused on what you actually saw, but my trailer now has a dual 30A system feed by a 50A to dual 30A dogbone. I added the second 30A service feed and you can see all I did HERE. Below is a pic of the 50A to dual 30A dogbone I made ...
I did this mod in lieu of converting my trailer to a true 50A service feed because of the cost of conversion and not wanting to wrestle that 50A Anaconda cord in colder weather.
โMar-29-2015 08:15 AM
โMar-29-2015 07:58 AM
โMar-28-2015 05:23 PM
CA Traveler wrote:
John,
The typical use of the dual 30A male to 50A female is on a 30A pedestal with a 20A plug and it's the 20A plug that is usually GFI protected. The GFI plug will trip and not work with this adapter.
โMar-28-2015 11:38 AM
โMar-28-2015 09:49 AM
Golden_HVAC wrote:I do not doubt you. But we traveled 7k miles last year from Indiana to Oregon and back and never saw a 30amp or 50 amp GFI protected receptacle in any campground. In fact I have not seen either in a campground in the last 14 years any where. Not saying they may not be out there though.
Hi,
I think that what you saw was a pair of 30 amp plugs going into a 50 amp receptacle. While it might work in some situations, modern RV parks use GFI receptacles, and will not work with that adapter.
You might find a few RV parks with a pair of 30 amp receptacles at a RV site, however it would be a 'pair' of campsites sharing a single power post, with two 30 amp plugs - 1 for each RV. SO if the neighbor's site is filled, they will use on, and you will only be able to use one of the plugs, and not this adapter.
Any 20 amp GFI that you plug this adapter into will trip, because all of the power going out on the 'hot' line is not returning on the 'neutral' line.
At first I was thinking that you saw a used RV with twin power cords. While that is possible, the past owner might have installed 'anything' - but RIVA will not allow two power cords on one RV, so it was not installed at the factory that way.
Good luck!
Fred.
โMar-28-2015 03:53 AM
