My question for the TC collective, has anyone noticed any efficiency degradation in amp output when both rooftop and the solar suitcase panels (on separate controllers) are used concurrently, on the same battery bank?
I am just about to purchase a 150W Renogy panel to mount on the roof of my Arctic Fox and run it through a TriMetric SC2030 controller which will be connected to my existing Trimetric TM 2030 Battery Monitor. I'm doing this to supplement recharging our 2-6V LifeLine batteries as our 100W Renogy solar suitcase isn't up to the task by itself.
In talking to a Renogy Tech today, I was informed that he was afraid that when I connect my 100W solar suitcase (with separate PWM ViewStar controller), to the same battery bank as to the rooftop 150W panel, the two controllers would sense power from the other charging source and dial back the output, degrading the efficiency.
I've read where others are doing this, (Mello Mike for one), but haven't read about any reduction in charging output. Any real world experience others would like to share before I put out the dollars for the rooftop panel?
Please limit feedback from those who have both a rooftop panel and a separate panel on separate controllers. I could put additional panels on the roof and not use the 100W suitcase unit, but I'm not willing to go that route yet until I get a solid consensus it the above setup works or is the tech correct that it won't work efficiently?
Thanks for any help.
2013 AF 996, 2013 Chevy 3500 CC,LWB,4X4, Duramax, DRW, 3.73 rear, Torklift Stableloads & Tie-downs,Fast Guns, Ride Rite Air Bags, Superhitch w/ 32" extension.Big Wigs, Front Timbrens, TST TPMS-507,CubbyCam, Trimetric. TM & SC 2030 150W + 100W suitcase
