โMay-20-2018 04:16 PM
โMay-31-2018 02:23 PM
โMay-28-2018 05:15 PM
Bill S. wrote:
Looks like you have a temporary fix for your trip. When you are ready to do a permanent repair, a number of solutions have been offered here, but I didn't see this one. You'll need access to the damaged area, which may or may not mean dropping to tank, but once you do, this product may be a good alternative, although I do like that JB Waterproof repair product.
Tank repair
โMay-27-2018 08:15 PM
mobeewan wrote:Bobbo wrote:
While this can't help you, you have helped me. I am preparing to screw some stuff to the floor of my RV in one of the closets. The water heater is in that closet and the water lines come up out of the floor. I have bought this Phone/Computer Endoscope so I can look under the floor before drilling to locate the water lines.
You might give a review of it when you use it. I'm looking at something similar, but I haven't purchased it yet.
I bought a Ryobi TEK4 inspection camera about 3 years ago since I already had a Ryobi TEK4 screw/drill driver that used the same battery. The camera works okay for what I've used it for so far but but it's a bit awkward and the cable is a bit short. You have to twist on the camera as you flex it to keep the camera orientation on the screen. It looks like later versions have a skinnier camera and thinner flexible cable.
โMay-26-2018 04:49 PM
โMay-26-2018 03:52 PM
โMay-26-2018 12:38 PM
โMay-25-2018 10:38 PM
โMay-22-2018 01:36 PM
Kober wrote:
Water rushing out in a few places of the thermal cover. I cut a 5 inch square hole through the cover where I had placed the new screw only to discover with a flashlight that I had screwed through the crossmember and into the fresh water tank.
โMay-22-2018 12:00 PM
โMay-22-2018 11:59 AM
bucky wrote:
The cross member appears to also hold the tank laterally. If that is the case you are probably dealing with an edge leak that is not flat. That is going to greatly complicate things.
Is the cross member bolted or welded in place at the frame rails? Bolted makes things easy, welded not so much.
Good luck with it.
โMay-22-2018 05:14 AM
โMay-21-2018 09:38 AM
โMay-21-2018 07:22 AM
dougrainer wrote:path1 wrote:
I'd try a "well nut" first.
The problem with using a well nut is, you cannot get a well nut to install THRU the metal support. He would have to pull the yank to install the well nut. Which he may have to do. Doug
โMay-21-2018 05:59 AM
Roadpilot wrote:
I'm not familiar with well nuts, but looking at the pictures, it looks like it acts like a rivet. As you tighten the screw the end in the tank flares out which would seal the tank from the inside. This would allow it to work even with the brace under the tank.
