Easy Start By Micro Air
1L243
I wanted to run my 13.5 Dometic AC on my generator but having only a 2000 watt Honda EUI, it was either buy a bigger generator or try the Easy Start from Micro Air.
I decided to go with the Easy Start. Installation was straight forward a youtube video was a great help.
After installation you have to go though a learning process for the Easy Start.
After the learning process I connected to my Honda 2000 and it ran the AC just fine. Prior to the Easy Start it would just trip the generator.
I tested amps at sartup prior to Easy start and it was around 32 amps. Now keep in mind this is just for a second when the compressor kicks on but enough to kick off the generator.
After Easy Start the start up amps are around 15 to 18 amps. It's so fast it's hard for the electrical monitor to record it.
The Honda has to be run on fast or run mode and not econo mode when using the AC .
For fun I thought I would see if the AC would run on my 2000 watt inverter and it did!
It was no different than running on the generator as far as the start up is concerned. Once the compressor kicks in the AC is running on about 12 amps.
I have a 500 watt solar system with 2000 watt Renogy inverter. My battery bank is 340 amp hours of lead acid.
I know I can't run the AC long on the battery bank that I now have but it will be interesting to see what happens when I'm dry camping in two weeks and see what the draw is on ac when solar is at it's peak of about 25 amps.
When ever I run a big appliance like microwave or coffee maker off my lead acid batteries my battery voltage drops to about 11.5 volts and it stays there until they appliance is turned off. Then the voltage creeps back up to the actual voltage. I understand this does not happen to Lithium batteries. It makes it difficult to monitor the battery voltage when under a heavy load.
So a big thumbs up to Easy Start by Micro Air
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
48 REPLIES 48
ktmrfs
Several dry campers we know including us have installed the easy start on 13.5K BTU AC units with very good results. However I will point out one thing to consider regarding the honda 2000 and the easy start. The honda 2000 engine is pretty much max'd out so output max power goes down with altitude. We found that around 3500ft density altitude the 2000 is likely to overload, luckily the easy start just shuts the AC down for about 5 minutes rather than having the honda completely kick out. This is with all other 120V loads including the converter power turned off.
solution honda 2200. it has a much larger engine and even at 8000+ft it can run the AC unit and still have about 300watts to spare. As a check with a honda 2200 we ran our AC at around 8000ft in 100F temps and I turned the fridge on AC just to see what would happen, 2200 kept on running, no overload.
Before the easy start I was lugging around two honda 2000's, paralleled for AC, when the honda 2200 came out i bought one, gave one 2000 to our son, and for a while carried around a 2200 and 2000 as a "just in case" for AC when boondocking. Gave that up, never have needed more than the 2200 even at very high altitudes. Solar charges the batteries,
2011 Keystone Outback 295RE
3_tons
Air conditioner on 400a/h LiFePo4 - A follow-up
As per my previous (pg 3), once back at home I decided to do just a โ€˜table-top exerciseโ€™ using a higher estimated amperage draw at say 95+d/f ambient temp, so in this example Iโ€™m using 100 amps/dc for the air cond. (rather than previous actual of 8.5a)
(Note, equipment used on previous pg.)
Previous duty cycle (post initial 20-25 min cooldown) averaged around 50โ€™ish % compressor run time (continuous low fan) - but for this example Iโ€™m using 60% duty cycleโ€ฆ
Air Cond, 100amps @ 60% duty cycle (averaged) = 60amps per hour.
660w PV @ 60% harvest (reduced average estimate over time) = 400wโ€ฆ400w = 22amp (hourly gain).
Air 60a/hr (incl. duty cycle) minus 22a (hourly avg. harvest over time) = 38a/hr avg. hourly amp/hr deficit.
400a/hr LFPโ€ฆ Assuming start-up at 90% SOC = 360a/hr available at start of table-top testโ€ฆ
38a/hr hourly deficit @ 5 hrs run time = 190a/hrs battery providedโ€ฆ
360a/hrs at start, minus 190a/hrs consumed = end of run battery @ 42% SOC or 170a/hrs remaining.
The averages used were merely intended to reflect the vagaries of solar over 5hrs of mid-afternoonโ€ฆ
A quasi-realistic thumbnail sketch only (JMO) - equipment and user experience subject to varyโ€ฆ
3 tons
ewarnerusa
Just another plug for the Micro air easy start, I installed it a handful of years ago and our Yamaha 2400 runs the 13.5 Btu A/C great. Usually I'm very diligent about turning off all other 120V AC loads when I do this, but this weekend I ran it for a while and later realized the fridge was on auto so it was using 120V AC power when plugged into the generator. Fridge draws 300 watts on electric and I suspect it was on the whole time because it was hot as heck out. Converter was off.
Aspen Trail 2710BH | 470 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
3_tons
โ€œ Now add more solar and the #s really start to look good. Less from the batteries and a little charge on off cycles. โ€œ
Well Iโ€™m kinda jealous (lol :)), but at now 660w (via an 8 panel home brew and two controllers - MPPT & PWMโ€ฆ) Iโ€™ve nearly run out of a truck camper roof space!!โ€ฆThe consolation though is that itโ€™s just a single-slide camperโ€ฆ
3 tons
Itinerant1
3 tons wrote:
Yep, oneโ€™s own instincts often tend to default to a required 1 to 1 harvest to demand scenario, but in a broader real world context this is not necessarily the caseโ€ฆ
What also needs to be considered is compressor duty cycle, concurrent harvesting, and the restoration of full amperage to battery charging that occurs in between each compressor ON-OFF cycle, and the โ€˜availableโ€™ battery Depth of Discharge (DOD) till start of the next dayโ€™s harvest cycleโ€ฆWhere battery storage is tight (as in a truck camper - resolved by under dinette mounting), Lithium is what makes this become viable possibility,,,
FWIW, total air conditioner run time (cycling - ending at 1915) was about 6.75 hrsโ€ฆ
Hope this adds some enlightenment ๐Ÿ™‚
3 tons
Now add more solar and the #s really start to look good. Less from the batteries and a little charge on off cycles. ๐Ÿ˜‰
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,500+ partial cycles.
3_tons
3 tons
3 tons:
Yes, interesting! I enjoy mind bending technical geek stuff..
Trying to wrap my little brain around it all is another thing - Haha! :B
That was a lot of work for you to do all that, record and post the results. Thanks for taking the time to do it. ๐Ÿ™‚
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
3_tons
While at Donner Lake todayโ€ฆ
I decided to do some raw meter testing, AFTER an initial camper cooldown from 84d/f to 77d/fโ€ฆStart of 1300 test, outside temp was at 90d/f, and end of test 1500 outside temp was at 88d/fโ€ฆ(FWIW, I took a nap in between these hoursโ€ฆ).
Equipment:
Two 200a/hrs LFP (actual load tested at 215a/hr per).
2000w ProSine PSW, pass-thru inverter-charger.
Victron SOC meter with bluetooth.
660w solar (serial add-onsโ€ฆ).
System is 12v, 0004 cables 6โ€™ roundtripโ€ฆ
Coleman Mach 1 P.S. 11kbtu air conditioner (w/Easy-Start)
Single full wall slide-out, 10โ€™ Eagle Cap Truck Camper.
Duty cycle (after initial cooldown period) was approx 5 min ON, 5 min OFF (fan continuous run on low). Readings were via Victron BMV-12 SOC meter:
1300 (compressor ON, fan low)โ€ฆ.Note, upon edit, to clarify (say upon test start) the -57amp figure (below) represents the difference between the amount being harvested vs air conditioner consumption, which is why the negative value referred to as the deficitโ€ฆ
Starting SOC: 85.5% (approx 340a/hr of remaining capacity at start).
Amps (e.g. deficit after harvest amount): -57amps (dc)
LFP Voltage: 13.05v
1500 (compressor ON, fan low)
Duty cycle had now increased to approx 8.5 min ON, 6.5 min OFF (fan continuous).
SOC: 72% (approx. 288a/hrs remaining capacity).
Amps (e.g. deficit after harvest amount): -54.5amps (dc)
LFP Voltage: 12.97
Using a separate hall effect meter at the inverterโ€™s 120v output (compressor ON, fan low):
Amps (ac): 8.5
Pf: 0.97
Hz: 60
Watts: 972
Voltage: 116
BTW, between compressor ON-OFF cycling, I used the Keurig one time at about 125 amps (dc), for an additional 2 a/hrs of battery consumption - Brewing completed before next compressor run call!!
FWIW (since writing the above summary - compressor ON, fan low), hereโ€™s two more unplanned readings at 1600, and 1700โ€ฆTemps are now starting to drop off a bitโ€ฆ.Iโ€™m expecting temps to be pleasant again starting at around 1800-1830 as sun angle drops offโ€ฆ(Cools off rather nicely here in the evenings ๐Ÿ™‚
1600:
SOC: 64% (approx. 256a/hrs remaining capacity).
Amps: -63 (dc)โ€ฆSome dang tree shading now over a couple of PV panelsโ€ฆ
LFP Voltage: 12.94
1700:
SOC: 55% (approx. 220a/hrs remaining capacity).
Amps: -73 (dc)โ€ฆHeavier shading
LFP Voltage: 12.90
Compressor duty cycle (at 1700 was 5 min ON, 6.5 min OFFโ€ฆ).
We maintained a comfortable 77d/f t-stat setting the whole time (still ongoingโ€ฆ). The main variable was the eventual tree shading of the panels, but still lots of battery reserve and will likely be at 90โ€™ish % charge (this, my โ€˜normal fullโ€™ by say noonish - except for periodic cell-balancingโ€ฆ
Most importantly (non-intuitively so!), note that in this example, harvesting at a rate of 1 to 1 ratio with power consumption is not necessaryโ€ฆHaving a deep enough reserve is whatโ€™s needed, aided by Lithiumโ€™s relatively flat discharge plateauโ€ฆ
Quite naturally, various equipment, camper size and user experience will varyโ€ฆThough understandably not for everyone, yet at least this provides an example of what might be achievable - havenโ€™t started the Honda 2200 in nearly a yearโ€ฆ
Oops, and this one final 1800 result for an even more comprehensive trend-line:
Compressor duty cycle (at 1800) was 3.5min ON, 9 min OFFโ€ฆ
Now starting to cool off nicely!
SOC: 45% (180a/hrs remaining capacity)
Amps: -76.4 (dc) still heavy shadingโ€ฆ.
LFP Voltage: 12.90
Total run time (including initial 100% duty cycle cooldown), 5hrs 25minโ€ฆ
Hope some find this example interesting โ€ฆ
3 tons
MNRon
Running AC off of 12v means LOTS of amps (100+ โ€”>200 depending on other minimal loads). It *can* be done, but LA voltage droop will be significant, Lithiums less so. Regardless, 100s of amps isnโ€™t great for lots of things, not the least of which is inverter circuitry. Few minutes for microwave, or hair dryer, etc isnโ€™t a concern IMHO but I wouldnโ€™t recommend it constantly for AC in high heat. Some do successfully; but my recommendation would be to set up a 24v system, or better yet 48v, if you want to run AC off of batteries a lot.
I have 540AHr lithium and a 3kW whole-house boost inverter, not saying Iโ€™ve never run AC off of my batteries but I have a 4500 Westinghouse generator that I use if I want to run AC. Even that only put out ~20A+ when we were camping at 9300ft a few weeks ago.
Back to OP original issue, I also have MicroAireโ€™s on both 15kW ACs. Doesnโ€™t change current draw while running, but eliminates the inrush current and loud bang when they start up, significantly reduces the voltage droop from batteries OR generator which are not as close to ideal sources as shore 120v.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
ReneeG
3 tons wrote:
ReneeG wrote:
What about a 15k btu ac, Easy Start and Honda eu2000i? Or do we need the 2200?
Honda 2200 is rated at 18.3a (short term), and 15a continuous, so youโ€™d need to check out your air conditioner amp specโ€™s to be sure, and have your onboard converter-charger disabled (at the breaker)โ€ฆ โ€˜Eco modeโ€™ might be somewhat questionable, though maybe possible with a soft-startโ€ฆConcurrent solar can take care of charging duties while the converter is disabledโ€ฆ
As previously mentioned, elevation and higher ambient temps will derate any generatorโ€™s output, so maybe a few actual users will chime in! JMO
3 tons
Thank you. We have an inverter and solar system, but we don't intend to use it for AC, yet this adds another thought.
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
3_tons
3 tons
ReneeG
Itinerant1
1L243 wrote:
bob_nestor wrote:
From other postings I've seen where people have tested running their A/C off batteries and they are reporting that you can get about 1 hr of run time for each 200aH of battery.
I wonder how long it will be before RV manufacturers start offering an option of placing Lithium-Ion (or sodium) batteries in the generator bay, installing an inverter at least 2800W, wiring all the 110v outlets and appliances in the RV thru the inverter, and putting Soft Starts in the A/C. And with Lithium or sodium batteries, installing the second high-output alternator in the chassis in addition to as much solar as then can fit on the roof.
While recently researching for my next RV I found one that I liked which I thought could be built this way quite easily to match my camping style. (I'm not looking to run the A/C on batteries other then when I'm traveling, hence the second alternator. Plus future battery technology may improve well beyond where it is now.) I figured I could replace the generator with about 1200aH of Lithium batteries (pricey, but doable). When I contacted the manufacturer with my requested changes, they flatly refused - said the generator couldn't be eliminated and they'd never wire the A/C and microwave thru the inverter. Reluctantly crossed them off my list and moved to other manufacturers.
If you want to be able to boondock all year round and run at least one AC you will need that large battery bank 1200ah in lithium would cost you a bundle. Throw in 1500 watts of solar on the roof and some nice Victron electronics and you into a 25k+ solar system not counting labor. Now if I had a little piece of land somewhere where I could park when not traveling maybe the price would be worth it.
I'll respectfully disagree. 500ah & 1,280w solar, I boondock fulltime with over 1,000 days in a consecutive stretch. I don't scimp on power, live like I'm pluged into the grid. ๐Ÿ˜‰
fj12ryder
theoldwizard1 wrote:
The Micro-Air EasyStart works differently than most "hard start" add-on, which is why it actually works !
Just curious what the difference is between the Micro-Air EasyStart and the SoftStart by SoftStartRV.
I am NOT intimately familiar with EITHER design, but the most common "hard start" add-on are basically just a large(er) start capacitor.
The short (lots of hand waving) electrical engineering explanation is as follows. Electric motors make their most torque (mechanical power) are zero RPM, so it makes sense that this is where they draw the most current (electrical power). A start capacitor gives them an extra "shot" to get them started (they likely would not start at all without the start capacitor)
The problem is, a fully discharged capacitor "looks like" a dead short until it charges up (less than a second). That split second is enough to trip the breaker. The solution is to limit how fast the capacitor charges up (limit the amount of current it can draw). Once the capacitor is "full" it discharges starting the motor. This all happens within 1-2 seconds so you don't even notice it.
DIY soft starter
Thanks.
Howard and Peggy
"Don't Panic"
Skibane
Microlite Mike wrote:
I have the Easy Start installed on my 13,500 btu A/C and power it with a Champion 2500 w Inverter generator. Does fine and will even start A/C when on 'Eco". Don't know what size engine in my 2500W Champion Inverter but I do know it's enough to run my A/C. Perhaps not for a 15,000 btu model though.
The amount of current demanded by an A/C varies quite a bit with ambient temperature - For example, Coleman lists their Mach 3+ as drawing 12.8 amps when in cooling mode, but also lists a 15.4 amp draw for "desert" conditions.
That's a 20% difference.
And, you also have to take into account the generator's reduced power output with altitude (approx. 3% per 1000 feet), less-than-perfect state of engine tune, fuel quality variability (i.e., amount of ethanol in the local gasoline)...
So, you have situations where a marginal generator starts and runs the A/C in moderate conditions, but not in extremes.
