Elect Brake Problem
bkick
I found that only one brake works when putting brakes on by pushing the brake pedal. All brakes work if I push the bar on controller. Have new controller and have checked all magnets, replaced one that was grease coated due to seal failure. Test light barley lights when brakes are applied. Found on broken wire truck side of connecter, repaired but make no difference.
Any ideas
Bkick
16 REPLIES 16
donn0128
Bad ground, mis adjusted brakes, mis adjusted controller are my first three guesses.
Bob_Olallawa
Do you have the controller set up properly and for right number of axles
Welcome to my home, that door you just broke down was there for your protection not mine.
