Landing gear question
taylorg
Lately I have been experiencing a front landing gear on my 2006 Keystone Challenger and looking for information. The motor seemed to slip and grind a little like it was low battery power but would still work if you let it rest. I replaced the gears, gear case and motor and it appeared to work fine. Today I was raising the camper to attach the pickup and it sounded like the motor was straining to left the camper resembled low battery power again. I was raising the camper to lift off pickup and motor started to slip again. Now motor slips as it is being lowered. Battery voltage was reading 13.7 no load.
Looking for information as to possible solutions
5 REPLIES 5
64thunderbolt
This is why I love my air bags.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
donn0128
I assume you have Venture Mfg landing gear, so I am going to tell you to contact them to order parts. While your at it convert to a dual motor setup. You wont regret it
taylorg
I have 13.4 volts when the motor is switch on. Tried to use the hand crank and cannot get the system to move. I may have a problem inside the jack.
rhochnadel
I have experienced your problems, I changed out the gears, and I changed out the motor. The motor has a slip clutch in it. Since I had two motors, I mounted one motor on each landing leg and added another switch. Now I can raise or lower each leg individually and there seems to be a lot less strain on the motor. Hope this helps, PM me if you need any advice.
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance":)
Old-Biscuit
What is battery voltage when using motor??
