Hey everyone - ready for "the season" but the only thing that's really on the squawk list this spring is the awning.
It had only worked "fast" (loud motor noise, in and out very quickly) a few times when I got it. It started working about half speed from then on. This unit has the touch-screen remote or the wall mounted switch - occasionally the wall switch or touch screen would work at full speed.
Last fall I went to retract the awning, and the motor barely moved it in - then it stopped working completely. Had to use a ratchet (didn't have an electric drill!!!) which took foreverrrrrrr.
I can see the control board at the front pass-thru storage area, with a bunch of relays on it. I believe this is only for the remote, as the relay clicks when I activate the awning.
I have a pretty extensive electrical diagnostic and repair / mfg background - I've just got large inaccessible gaps in the wiring that I'm not sure about here - figured I'd ask the board before I dive in.
For now my approach is going to be getting a power source (jump box etc) and applying power at the awning motor itself. If that works, I'll do the same at the wall switch and the remote relay board. If those work fine, then I've got a power supply problem to both circuits. Since neither work, I'd put my money on this as being a source of the problem anyways (or the motor itself, but that's unlikely for a new unit with hardly any use).
What do you all think?
2016 Springdale Summerland 2570RL Arctic
2006 Land Rover LR3 V8 HSE | OE tow pkg & air suspension
