โSep-13-2013 03:02 PM
โSep-13-2013 08:21 PM
โSep-13-2013 08:12 PM
โSep-13-2013 05:58 PM
โSep-13-2013 05:50 PM
โSep-13-2013 05:45 PM
RoyB wrote:
I suspect If he is feeding the 50A plug with a 30A source he has to use the standard adapter that has the 50A side LEG1 strapped to LEG2 like this DMBRUSS drawing. Without the strap he is only feeding one side of the 50A system
who knows how he is setup - need more info
โSep-13-2013 05:09 PM
โSep-13-2013 04:25 PM
โSep-13-2013 04:02 PM
โSep-13-2013 04:00 PM
rocmoc wrote:docj wrote:2oldman wrote:
By 'both sides' I'll interpret that as both legs of a 50a circuit. OK..
I'm a little behind on my 50a knowledge, but I do know it's two legs. So.. is that inverter designed for 2-120vac outputs? I've never seen a "50a" inverter.
I realize that it's probably not worth speculating, but my MH had its inverter wired through a subpanel with two breakers. One of the breakers handled the microwave and an outlet or two and the other had everything else. If that second breaker tripped the effect would have been as the OP described it, but it wouldn't explain why everything works in pass-through mode.
I'm as puzzled as everyone else; maybe the OP can provide more info.
Yup have a second breaker panel but everything is working. Will check a third time just in case.
rocmoc n AZ/Mexico
โSep-13-2013 03:40 PM
โSep-13-2013 03:38 PM
โSep-13-2013 03:34 PM
โSep-13-2013 03:19 PM
โSep-13-2013 03:11 PM
