Electric problem and question
path1
Due to medical problems we can't use RV as much as possible. Lately my battery under the hood (2003 Ford F-350) keeps getting low. I'm going to buy a battery load tester later in week. Battery is 9 years old, so probably battery. But I want to make sure. In the mean time...
I don't see anything on or being used in the house part. The house battery doesn't go down, only the starting battery. I'm thinking propane alarm, but not sure as wires get lost behind wall.
How do I test with volt meter if any elec is going from starting battery to anything in house part of class C?
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
13 REPLIES 13
westend
The original Motorcraft battery in my 2003 F-250 was in service for 10 yrs, 1 mo. I babied it along for the last year of it's life. After I replaced the battery, I also had to replace the alternator. Learned a lesson there.
'03 F-250 4x4 CC
wa8yxm
9 Years is when my battery decided it needed to retire.. So I'd guess that's what's happped here.. I dropped (Well lifted in my case) a new DEKA battery onto the tray and ... Well.. I expect I have about 6 more years before I have to do it again (It has been actually 4 years since I replaced it)
House batteries went a few months later.
tenbear
You might also want to get a clamp-on ammeter to measure the current being drawn by the battery. If you do, make sure it can measure both AC and DC.
2010 Subaru Impreza Sedan
path1
Op here... Thanks for replies. I'll get new battery.
Thanks for replies.
time2roll
Do you really need to baby this thing along until it dies on the road?
With nine years of service get a new chassis battery at first sign of weakness(today).
Lwiddis
Test it all you want, in fact a good idea, but buy a new battery....9 years!
2oldman
If you don't want to replace a 9yo battery, make sure you carry jumper cables and have good ERS.
DrewE
A nine year old car or truck starting battery owes you absolutely nothing. I don't think there's any need to test it as it has simply worn out with age and use. Replace it and hope the new one lasts equally as long. (By way of comparison, it would appear that the original battery lasted about half as long prior to being replaced with the current one.)
pianotuna
Nomad II
Nomad II
Hi Path1,
I forget if you have solar. If so, add a Trik-L-Start or an Amp-L-Start.
I have the TLS and love it.
Regards, Don
MEXICOWANDERER
A good quality AGM battery can endure short cycling a lot better than any flooded conventional battery. A rational battery tester costs more than a new battery. It used to be Interstate Battery DISTRIBUTORS employed adjustable carbon pile battery load testers. Wal-Mart grade Battery Dept cheese grater load testers are worse than useless.
MrWizard
Moderator
Moderator
Radio memory, engine cup, transmission electronics
Some things are always connected
Long storage non use time with old battery
Replace battery and install a battery tender, or a small solar maintainer
I can explain it to you.
1997 F53 Bounder 36s
VoodooMedicineM
9 years old?
Time for a new battery
Bill and Joey the dog
TucsonJim
Disconnect the positive battery terminal. Set your meter to current, and then hook the negative lead to the battery cable and the positive lead to the battery post. This is how you measure current flow.
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
