Electrical issue
surgtech56
We have a 2011 Ameri-Lite. I plugged it into the house using an adapter last week. Everything was ok. Went out today, the microwave has power at least the clock is, no lights come on, I have refrigerator on auto, when I turn on lights the refrigerator light dims, refrigerator is not cold. Any idea thank you
17 REPLIES 17
MrWizard
Moderator
Moderator
Very common , usually involved one or more of these things
Battery disconnect is used, battery not connected
Bad cable
Converter is bad
40 amp automotive auto reset thermal breaker for battery is bad, located under frame near tongue, in main positive cable line
I can explain it to you.
1997 F53 Bounder 36s
Artum_Snowbird
Battery voltage has dropped to almost nothing. Could be converter is shut off, so start there. Check output voltage of converter on 12 volt terminal strips. If it shows over 13 volts, then check at battery posts. If it doesn't show the same there, look at the connecting wires.
In my case the negative feed to the battery at the converter terminal strip was loose, preventing the battery from charging.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Toddupton
Battery is dead. Is it charging? Did it get hooked up backwards?
