โDec-22-2016 08:05 AM
โJul-08-2017 06:17 PM
โJul-08-2017 10:35 AM
โJul-08-2017 05:26 AM
time2roll wrote:
You can get waterproof wire nuts in the landscape department.
At least turn them up to avoid trapping water.
I would zip-tie around the axle before those stickers are in the wind.
โJul-07-2017 09:49 PM
โJul-07-2017 08:06 PM
โJul-07-2017 02:43 PM
BruceMc wrote:
Looking good!
On our fiver, I struggled with uneven braking. With decent trailer brake sensitivity set, the left front tire would consistently lock up followed by the left rear. I don't thing the right ones ever locked up.
I pulled all the factory wiring (connected with scotchlocks, if I recall) out & replaced it with highly flexible rubber sheathed extension cord cable. I ran 10 gauge to a point near the axles, 2 EQUAL lengths of 12 gauge to the center of the axles. At that point, I ran EQUAL lengths of 14 gauge to each brake.
All connections were soldered & weather shielded; the cord was attached to the tops of the axles with a spot of adhesive and electrical tape. No connectors were used except the crappy 7 pin on the pin box.
It worked very well. I never had lockup issues; all 4 wheels braked at the same rate. It became a pleasure to tow ... then I traded it in on our first Class C. I hope the future owners enjoyed it as well as we did!
โJul-07-2017 01:59 PM
โJul-07-2017 01:40 PM
PUCampin wrote:
In my case, my OL, Short, Not Connected, error codes were caused by the wires inside the drums being too long. In 2 of the 4 wheels, the drum rubbed through and the wire made intermittent contact with the rotating drum causing all kinds of issues. If you have not removed your drums and checked this, do so.
โJul-07-2017 01:28 PM
RCMAN46 wrote:
Two things.
First you need to replace the wire nuts with waterproof crimps.
Wire nuts will allow the connections to corrode and will not be able to handle the vibration they will be exposed to.
Second the P3 has a diagonistic feature that will give the current drawn by the brakes.
I have found the current will be very close to 1 amp per volt applied.
This correlates close to the resistance you measured.
I check the voltage applied and current drawn before every trip with the manual lever on my P3.
โJul-07-2017 01:16 PM
โJul-07-2017 01:04 PM
Bigbird65 wrote:
The wiring has been completed. No telling how long I have been running with only 75% braking. I found that on the right front one of the magnet wires was out of the original factory crimped connection. Before I started, measuring with my Fluke meter, the brakes measured 1.5 ohms at the trailer connector. After the rewire the measurement is 1.1 ohms. It will now be really easy to isolate a magnet. Hope to take it out for a spin tomorrow to see if I helped the overload alarm.
โJul-07-2017 12:23 PM
โJul-06-2017 06:16 PM
โJul-04-2017 11:52 AM
