โFeb-18-2014 05:57 AM
โFeb-18-2014 07:56 AM
โFeb-18-2014 07:52 AM
jornvango wrote:No.
After I reconnected the negative cable to the battery, I re-tested the battery and it's showing 12.67 V.Good news for the converter?
โFeb-18-2014 07:45 AM
TucsonJim wrote:
The converter is "probably" not functioning now. As BFL13 noted, you should be around 13-1/2 volts at the battery with the rig plugged into shore power and the batteries charged up. One way you can be 100% certain about your converter output is to remove the negative battery cable from the battery. Then, check the voltage from the negative battery cable and the positive battery cable (still attached to the battery). If there is no voltage, then the converter is not working.
โFeb-18-2014 07:20 AM
โFeb-18-2014 07:10 AM
โFeb-18-2014 07:06 AM
โFeb-18-2014 06:58 AM
BFL13 wrote:
With shore power on, your battery voltage should be 13.6ish from the converter. It appears you lost the converter, but what brand and model is it before we try to guess remedies?
Meanwhile you should have/get a portable battery charger for the rest of your trip in case you can't repair the converter. You can get by with 120 shore power and 12v from battery as long as you have a battery charger.
You could try the MW in a different receptacle that is for sure working just to see. Unplug the MW and use an extension cord to the other receptacle.
โFeb-18-2014 06:39 AM
โFeb-18-2014 06:23 AM
โFeb-18-2014 06:21 AM
โFeb-18-2014 06:18 AM
