โAug-14-2014 05:24 AM
โAug-22-2014 10:36 AM
โAug-16-2014 05:50 AM
Almot wrote:brulaz wrote:
The Rogue MPPT controller puts out a median daily 10Ah to maintain the batts with all that stuff on. That may include what the Rogue uses too.
When not generating energy, Rogue itself uses very little, 0.26 AH in 24 hours.
Battery self-discharge is also a contributing factor. Battery in a good shape can draw anywhere from 0.2 AH to a few AH a day, depending on battery type, size and condition, and on ambient temperature (faster self-discharge when hotter).
โAug-15-2014 06:49 PM
โAug-15-2014 05:15 PM
โAug-15-2014 01:52 PM
JRS & B wrote:
Googled electricity consumption by appliances while in the standby mode. I figured the ones operating at 110 volts would dwarf the stuff operating at 12 volts. ...
I'm still guessing the extra 8 kWh comes from keeping water hot or maintaining a dying battery on life support.
โAug-14-2014 06:33 PM
kellertx5er wrote:Mandalay Parr wrote:
Sounds about right to me.
That's about $15.
Unless power in Phoenix is $1.50/kWh, I think you missed a
decimal place. At $0.15/kWH, it would be $1.50 per week.
โAug-14-2014 02:09 PM
โAug-14-2014 02:03 PM
JRS & B wrote:
MEXICOWANDERER - Our Direct TV HD DVR's go into a sleep mode if not used for 4 hours. So the newer receivers are more frugal.
โAug-14-2014 01:35 PM
That's about $15.
โAug-14-2014 12:30 PM
โAug-14-2014 12:12 PM
โAug-14-2014 12:05 PM
โAug-14-2014 11:53 AM
โAug-14-2014 10:55 AM
kampinguru wrote:
I have noticed that I am using about 10KWH in that amount of time. Now the only things I can think of that might be drawing electricity is the TV and Satellite receiver, the Propane detector and the converter/Charger. I am running my fridge on propane so none there. Is this a reasonable amount of electricity to use in 5 days? Thanks
