โAug-30-2013 03:35 PM
โSep-08-2013 10:19 PM
onecb wrote:
"โขHarbor Freight sells an inexpensive 500 amp adjustable load test machine. I love it as doing a load test alongside a hydrometer inspection and equalization is a great dose of truth serum." I bought one of the load testers and I really do not understand the test or the results when used on a pair of 6 volts? Could one of you knowledgable people explain it to me? Thanks Alvin
โSep-08-2013 09:50 PM
MEXICOWANDERER wrote:
Boy talk about aching fingers* causing the brain to fingers to short-circuit. Yes,.015 is correct my figure as listed is incorrect.
*Shoulders, knees, #4 lumbar disc, toenails, hair, etc.
โSep-08-2013 08:52 PM
โSep-04-2013 03:29 PM
MEXICOWANDERER wrote:Amperage will drop and voltage will rise as the equalization process continues When a series pair of batteries reaches 16.0 volts stop the charging. Go to the next battery or batteries and let the first ones cool off. If you are doing a single 6 volt battery apply 11 amps until 8 volts is reached Redo the hydrometer check.
โAug-31-2013 06:58 PM
โAug-31-2013 06:16 PM
โAug-31-2013 05:41 PM
Snowman9000 wrote:
So what is top charging, then? Just a quick bubbling to equalize the electrolyte?
โAug-31-2013 05:02 PM
โAug-31-2013 03:37 PM
โAug-31-2013 03:24 PM
โAug-31-2013 02:25 PM
โAug-31-2013 12:50 PM
โAug-31-2013 12:36 PM
โAug-31-2013 10:58 AM
