EU2000 wire harness plugs
StewB
Does anyone know a part#, type or model# for the stop switch/fuel valve wire harness plug? Even better would be the name of a supplier. I want to be able to unplug the harness from the stop switch and plug a second stop switch into the main harness.
Thanks for any help
Stew
5 REPLIES 5
StewB
Thank you very much. They look like the right ones.
trailrider
I bought the switch at the local Honda dealer for $12. I was amazed they had it in stock. Compared it to pics I Googled up. I think I found the correct setup. It is called HM 090 series. The top item on these two sites:
http://www.cycleterminal.com/hm-non-sealed-series.html
http://www.easternbeaver.com/Main/Elec__Products/Connectors/090_Connectors/090_connectors.html
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
StewB
Local Honda guy want $30 Can$ for the switch with plug. In the US they are $12. US$
Project is on hold.
I go to the US several times a year on business so I will pick one up next time I am there.
trailrider
You could get the switch and just use that half of the plug if you can't find the plug only. It's only $13.35 on this parts breakdown: http://www.hondalawnparts.com/oemparts#/Honda_Power_Equipment/EU2000I_A%2f%2fB_GENERATOR%2c_JPN%2c_V...
If you find the plug only, be sure and let us know on this thread. I would like to do the same thing you are attempting.
2007 Komfort 277TS
2017 Montesa 4RT260
2021 Honda CRF450X
SoundGuy
Your local Honda Powersport dealer.
2012 Silverado 1500 Crew Cab
