โSep-07-2015 10:24 AM
โSep-10-2015 01:13 PM
โSep-10-2015 01:05 PM
Wotta hoot. The era of rationalization.I know a guy that has a vacuum cleaner with an indicator light on the cowl. It tells him when the floor is clean.:B
โSep-10-2015 12:57 PM
โSep-10-2015 11:48 AM
landyacht318 wrote:The real test data will be if the battery starts your car or boat after the light turns green.
I'm gonna put my Schumacher back together and let it loose on my screwy31, then after it flashes the soothing green light, supposing it does not goto 16.4v or higher and shut itself off, and see how many more AH my Meanwell can stuff into it before Sg no longer rises.
Ah never mind, whats the point? Actual Data means nothing, compared to a marketing page and blinking green lights, to somebody defending their purchase and their misplaced faith.
โSep-10-2015 11:00 AM
โSep-10-2015 10:43 AM
โSep-10-2015 09:43 AM
โSep-10-2015 07:52 AM
โSep-10-2015 06:15 AM
โSep-10-2015 05:47 AM
MEXICOWANDERER wrote:
But answer me this point What is the difference between a smart battery charger and a smart converter when boondocking?
โSep-09-2015 09:41 PM
โSep-09-2015 09:14 PM
โSep-09-2015 05:40 PM
RJsfishin wrote:
How many times have we heard of some hi voltage from an automotive charger killing any of our electronics, except maybe some cheap led lite that should never have been bought in the 1st place.
I also have a Schumacher charger that goes over 16 volts on most any battery I stick it on. But it has not caused any problem. Why ? Probably because it is an automotive charger made for vehicles whose electronics that can handle some 16+ volts now and then,....maybe forever. If they were to fry electronics, don't you think there would have been a recall on them ? DUH!!
I will add that I have had 2 cheap defective solar controllers pump out 17+ volts for who knows how long before I noticed it. And it hasn't hurt any control boards, or anything else that I know of.
The answer to the OP question (read his lips) is keep doing what you are doing !! Automotive smart chargers mommies didn't raise no dummies !
โSep-09-2015 05:25 PM
Smart "chargers" are designed to be SOLD to dummies, and others who refuse to do what had been done for the last 100 years with lead acid batteries. PT Barnum put it best.
