External Sediment Water Filter
AllegroD
We have a whole house filter, which is a carbon filter for removing chlorine and bacteria of water entering the coach, from city water or the tank. We are adding an external filter to remove sediment. We can easily add an external Flownatic housing. Do not want to remove chlorine from water entering the tank. Do not want to go RO or softener.
Looking for recommendations on sediment filter and source. Whole system recommendations are welcome, also, as long as they are for sediment removal.
5 REPLIES 5
martipr
Go to the expert http://www.rvwaterfilterstore.com.
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
AllegroD
Excellent, Thanks.
dbbls
I get my sediment filters at Home Depot, 5 micron and it fits a standard filter housing.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
WyoTraveler
I use a 5 micron sediment filter. Standard 10 inch filter
MEXICOWANDERER
Rotoplas 1-micron filter with cartridge inside screw on housing. Captures amoebas and protozoa. Amazing degree of filtration.
