โFeb-05-2023 02:52 PM
โApr-12-2023 07:04 AM
ewarnerusa wrote:
Wow, it is working great! I'm shutting this test down as the water is getting hotter than expected and I'm not available for continuous monitoring. 66F to 130F in a couple hours. I realize this is just a tiny volume compared to 6 gallons, but this little sucker is cranking out heat just using current that the battery isn't needing for absorption charging. Panels are harvesting 15 amps, looks like between 7-10 amps are going to the diversion load element, the remainder is going to maintaining the batteries at absorption setpoint, the laptop charger to run the laptop in order to monitor stuff, and any other camper parasitic loads (not that there is much, it is sitting in storage at home).
Click For Full-Size Image.
Laptop hooked to the SCC to monitor things. Interesting that when wired up for diversion load, the charge current shows 0. I believe this is because the panels are not actually hooked to the SCC in diversion load mode. They are hooked directly to battery and SCC monitors battery voltage, allowing anything in excess of charging setpoints to flow to the diversion load.
Full current from panels right now is 15 amps:
โApr-11-2023 10:12 AM
โApr-11-2023 08:10 AM
pianotuna wrote:
ewarnerusa,
I for one, will be waiting with baited breath on the results!
โApr-10-2023 03:17 PM
โApr-09-2023 08:06 PM
โMar-05-2023 10:06 AM
โFeb-25-2023 04:59 PM
โFeb-19-2023 08:28 AM
โFeb-18-2023 07:14 PM
ewarnerusa wrote:
To me, the cool part about the diversion load idea is that 100% of solar harvest capacity is used throughout the entire solar day.
โFeb-13-2023 06:39 AM
Cptnvideo wrote:
"IMO, in order to actually use excess solar capacity, add battery storage capacity so the excess power can be used when needed."
Exactly. That is the correct thing to do.
โFeb-13-2023 06:09 AM
โFeb-13-2023 06:03 AM
Grit dog wrote:
^Youโre still barking up the wrong tree. No, 1 280W panel wonโt power a space heater either.
At best 100% solar power being absorbed, it will kick out 8-9amps at 12v +-
Good luck. I know you so want to โmake this workโ but the practicality of it is of seriously diminishing returns.
โFeb-13-2023 06:00 AM
ewarnerusa wrote:StirCrazy wrote:ewarnerusa wrote:Chum lee wrote:
As previously hinted at, if you have a 2/3 way absorption type fridge, why not divert the excess power generated to that and save some propane? Clearly, if you have a 2 way fridge, you'll need an efficient inverter capable of generating at least +-500 watts on a duty cycle of at least 50%. Just keeping your 1500 watt PSW inverter online full time may be enough to waste enough excess power to solve your issue doing nothing else. IMO, 280 watts of solar wont be enough to run the fridge full time, but hey, it's a start. You'll be spending a lot of time doing load management.
Chum lee
A different take on this idea^^ I wonder if instead of a 12V water heater element I could explore a refrigerator 12V element? Is there harm in adding variable/inconsistent heat (less than the OEM 300 watt AC power element) to the ammonia in an absorption fridge? This is just a brainstorm, I definitely don't want to swap out the AC side of the fridge.
EDIT: I clearly don't know exactly how the ammonia is heated in an absorption fridge, just that this is part of the process. But first google search showed a promising success for a similar idea. This is a Dometic fridge, mine is Norcold. https://www.escapeforum.org/forums/f8/adding-12v-heating-element-to-rm2510-fridge-16224.html
my 3 way on 12V is 12 amps. thats a lot of power to be chucking out for the return on propane savings.. I can go probably between 1 and 2 months on just my fridge with a 20lb bottle, but as soon as your solar stops producing over the amprage for the 12v heater then you have to turn your fridge back to propane or you start eating battery capacity. Idealy you want somthing that you don't have to interact with in my opinion. the hot water element would be great, in my case the space heater would be good but in the summer you would have to be able to turn it off and you would still be not using all your potential when its hot... maybe a combanation of the water heater and space heater so you can use which ever one you want.
Steve
Thank you for this. Do you think both a water heater element and a space heater could be paralleled on the diversion load circuit each with an on/off switch?
โFeb-13-2023 05:56 AM
ewarnerusa wrote:
Then we have the kind of online gambling shopping when trying something from Ali Express. The 1/2" NPT size means it could swap with my 1/2" NPT thread drain plug, right? This would be ideal, maintaining my OEM 120V AC 1400 watt heating capacity.
Dernord Immersion Cartridge Heater Hot Rod Heating Element Replacement with 1/2"NPT Thread 12V 24V 1...
โFeb-12-2023 05:28 PM
