fifth wheel front landing legs
wayne1234
My son in law has a fifth wheel and the front legs won't work on the twelve volt battery but will once the trailer is plugged into 110volts they work. Can anyone tell me what to check for.
Thanks,
Wayne
3 REPLIES 3
enblethen
Legs should come straight off the battery. Look around the battery for a fuse or circuit breaker. Some circuit breakers have small reset button.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CincyGus
bid_time wrote:
Dead battery or disconnect switch in off position.
What he said. Legs run on 12v power so the motors not getting power until you plug in. $ to a donut it's one of the two or a bad ground from the motors negative wire.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
bid_time
Nomad II
Nomad II
