โJul-07-2018 05:13 AM
2018 RAM 3500 Dually 4x4 crew cab
,โSep-06-2020 08:36 AM
tewitt1949 wrote:
Some axles are made with camber (or caster, can't remember which) built in. The tires tip out on the top. The axles are bent upwards a little in the middle. Some axles are straight.
โSep-06-2020 03:10 AM
โSep-05-2020 05:57 PM
โAug-28-2020 12:54 PM
โAug-28-2020 05:52 AM
,โJan-15-2020 07:08 PM
โJan-15-2020 02:20 PM
trail-explorer wrote:
I've done a few "spring over axle" conversions. Flipping the axle is a no go. If you flip the axle, the tires rotate the wrong direction and then the brakes won't work
โJan-15-2020 12:59 PM
โJan-14-2020 05:46 AM
โJan-14-2020 01:57 AM
โJan-13-2020 01:46 PM
โJan-13-2020 01:40 PM
โJan-13-2020 11:20 AM
TakingThe5th wrote:
FYI-do not use cinder blocks on this project. They can crumble. Use boards.
โJan-13-2020 06:58 AM
