โFeb-21-2021 04:01 PM
โMar-04-2021 07:09 AM
Itinerant1 wrote:
You can get 280 cells fairly cheap add a bms and no soldering needed. You have better help at diysolarforum.com and lot of reading on this subject and everything else speculated in this thread. Need warming pads for cool weather there is section there for that and a good thread going on now.
โMar-03-2021 09:32 AM
โMar-03-2021 07:14 AM
โMar-03-2021 06:10 AM
โMar-03-2021 06:00 AM
โMar-03-2021 05:23 AM
โMar-03-2021 03:37 AM
โMar-02-2021 08:49 PM
KJINTF wrote:
Itinerant1
It's a home brew hybrid Pb/Li system with several different charging parameters and charging sources. A hobby that turned into an obsession.
To date have not removed the Li cells from the RV but have once or twice manually balanced the cells with external loads.
We have several custom modified converters along with DC-DC chargers (just returned a Victron Orion-TR Smart 30amp IMO a POS due to it's lack of functionality, no way to adjust the output current) along with solar.
Always something to keep busy never dull moment
โMar-02-2021 08:42 PM
pianotuna wrote:
Hi Steve,
On the same search I found this:
https://www.google.com/url?sa=t&rct=j&q=........169.pdf&usg=AOvVaw2oM6Shas53tE_nwfu5c5NT
"Through experimental analysis of batteries, we draw the conclusion that LiFePO4 battery has a long cycle life, good safety attributes, a high theoretical capacity, low environmental impact and other characteristics; however, it also has many shortcomings, such as need to prevent over-charge, over-discharge, and over-temperature. Otherwise, utilizable capacity of the battery will decrease rapidly, and cycle life will reduce quickly."
Translation: LiFePo4 are unforgiving of any abuse and may bite you in the behind.
One needs a magnificent battery management system. It is not in my skill set to design such a beast.
โMar-02-2021 10:25 AM
KJINTF wrote:
Itinerant1
โMar-02-2021 10:19 AM
โMar-02-2021 10:13 AM
KJINTF wrote:
3 Tons
Now you know of someone that operates a home made 200amp 4 cell LiFe prismatic battery with no "installed" BMS. I built it from CALAB cells several years ago. It is my belief there are many others with similar installations most just not making comments here. Mine has been installed and fully operational for well over 5 years in the RV. I have a few Cell Log 8 battery monitors and audio visual alarms to help me keep and eye on the individual cells, nothing more. So far all has been wonderful no balance issues with charging or discharging. One of the best upgrades to date for our old RV.
โMar-02-2021 10:03 AM
pianotuna wrote:
3 tons,
I'd have to disagree about the well vetted. For example SiO2 was first developed in 1951.
I do agree and said the BMS is required. No one but a fool would use any Li "raw".
โMar-02-2021 09:59 AM
KJINTF wrote:
3 Tons
