โSep-17-2018 06:39 AM
โSep-17-2018 04:45 PM
โSep-17-2018 04:30 PM
โSep-17-2018 04:17 PM
โSep-17-2018 04:14 PM
โSep-17-2018 03:05 PM
โSep-17-2018 02:25 PM
โSep-17-2018 02:14 PM
Chris Bryant wrote:That's what I would have thought, but a look at the wiring diagram reveals that the eu6500i has dual 3-phase windings, feeding separate inverters contained in a single physical module. The windings and inverter outputs are identified as "M" and "S", which could mean "master" and "slave". I've noticed a couple reports of eu-series inverter failure over the years, but they are extremely rare.
Keep in mind the generator is a 3 phase which is, I believe, rectified to do, then run through the inverter, so the load on the generator is the same either way, instead of load on windings, it will be load on inverter. That said, it would probably be easier on the inverter, but I've never heard of a Honda EU series inverter failure.
โSep-17-2018 12:13 PM
โSep-17-2018 12:00 PM
โSep-17-2018 11:50 AM
โSep-17-2018 11:49 AM
โSep-17-2018 11:09 AM
MrWizard wrote:
what else is using 120v power
fridge ? water heater ? converter ?
might be better to just swap some breakers around in the power center
to balance the load
put them on the other leg
you have 23amps per leg in the 240v mode using the (4) wire 240v outlet
moving circuit breakers to shift and balance your load is the best option
you have an unbalanced load , it will still be unbalanced even on 50amp shore power
this is NOT a generator problem
โSep-17-2018 10:00 AM
โSep-17-2018 09:27 AM
DrewE wrote:
I don't think it would make a big difference in your case in terms of durability. I would suggest using the 240V setting
. (In theory, it could be possible to work better with an unbalanced load where one leg is more heavily loaded than the other with proper wiring of a cordset combining the two 120V outputs from the two twist-lock connectors when running in 120V mode, but errors in making or using such a cord could be problematic or even dangerous and I think the gains would be minimal in practice.)
