โAug-22-2013 10:45 AM
โAug-22-2013 05:29 PM
travisd1000 wrote:
Also, thanks all for the quick replies.
@dougrainer - since this one is cracked, are they available as a service part?
โAug-22-2013 03:56 PM
โAug-22-2013 02:28 PM
travisd1000 wrote:
Is a dip tube necessary when the cold water already enters at the bottom of the tank? It's basically drum laid on it's side, with hookups at 12 and 6 o'clock. The lowest is the inlet already, so a dip tube isn't going to change much such as you would need for a household water heater where the inlets come in the top.
Or am I missing something?
โAug-22-2013 01:00 PM
โAug-22-2013 12:53 PM
โAug-22-2013 12:38 PM
โAug-22-2013 12:07 PM
Hondavalk wrote:smkettner wrote:
I assume it is a dip tube to direct incoming water to the bottom of the tank as you draw hot water off the top.
X2
โAug-22-2013 12:01 PM
โAug-22-2013 11:37 AM
โAug-22-2013 11:15 AM
