Freightliner chassis exhaust brake 2003
islandvagabonds
Hello all, my exhaust brake on my 2003 Discovery has been operating intermittently for the past year. Technicians have been challenged to remedy the problem. The exhaust valve is new 12 months ago and worked well for a while. Indicator lights on the dash show the brake is operational but the tranny does not down shift nor does the valve close on the exhaust. Does anyone know how to test the valve operation while parked?
thanks for all comments
bob
3 REPLIES 3
mchero
If the tranny is not downshifting its not the valve. Check the switch on the throttle assembly.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
Sierra_Valley_M
I had a similar issue on a 1992 Monaco Dynasty. It was resolved by sending the ECU to Transmission Instruments in Texas. The power supply was rebuilt. Works perfectly now.
'92 Monaco Dynasty
Sierra Valley, one of the last rural places left in Northern California.
wolfe10
Get a wiring diagram from your chassis maker. The problem is likely in the dash area with the signal not getting to the Allison ECM. There are some relays involved-- one may be going out.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
