โAug-09-2015 03:22 PM
โAug-12-2015 09:52 PM
Wrace wrote:
Sent the local RV parts/dealer a picture of the inlet and he replied that they had these in stock - all the same plate/inlet but three different versions with different connections.
"One that is plastic check valve ยฝโ MPT We have one that is brass check valve with ยฝ MPT and one that is brass check valve with ยฝโ female pipe thread. They all look the same from the outside".
So I guess I'll pull this one out and take it with me to the store. Their price is likely going to be higher than online but I have the time today to work on this thing and would like to get it done and off my list.
โAug-12-2015 10:16 AM
โAug-12-2015 06:32 AM
โAug-12-2015 02:07 AM
Wrace wrote:We've used an infill of silicone caulk, held in-place by duct tape for 72 hours, then remove duct tape and hit it again with an infill of silicone caulk covered by duct tape again. That's held-up over 10 years and no complaints yet. Gorilla Tape will work too, if you can't find duct tape.
Thanks for the replies.
Short term I'll try stacking some washers in there and see if that existing plastic plug will seal. As it is the plug stops well short of sealing against the single washer. If that doesn't work I'll try the pvc plug. That will at least get me through this next trip.
There is little chance of getting to the inside where this inlet is mounted as it's buried behind the tub.
I'm wondering how this is typically replaced? Unscrew the plate, break the sealant and then the whole connected assembly pulls out far enough to unscrew the inlet and replace with the new one?
Or is the fitting that the inlet nipple screws into fixed to the floor and the inlet must be screwed into it, hoping that it screws in far enough to make a good seal (with tape) and at the same time the plate stops flush against the side of the trailer? If that made any sense...
โAug-10-2015 08:08 PM
Dutch_12078 wrote:
The quick "fix" is to just screw on an inline hose shutoff. They're about $2.50 at the nearest Walmart or home improvement store.
โAug-10-2015 09:54 AM
โAug-10-2015 06:50 AM
โAug-10-2015 05:40 AM
โAug-10-2015 05:18 AM
computerbug wrote:
Old biscuit Can we have your private number or do you have a team?
โAug-10-2015 05:03 AM
Chris Bryant wrote:
There is no reason that plastic plug should not hold pressure, just screw it in tight.
โAug-10-2015 03:19 AM
โAug-10-2015 01:43 AM
โAug-09-2015 07:56 PM
โAug-09-2015 05:23 PM
