Hi,
Thanks for the report on the ARP unit!
My chimney fans are in a mask at the top and do create quite an updraft. They are thermostatically controlled to cut in at 70 f. They also restrict air flow somewhat in winter time allowing me to heat the outside more easily.
The interior fan, so far as I can tell, reduces the run time on the fridge. i.e. it runs less REDUCING the load on the cooling unit.
So far the maximum temperature I've seen on the ARP v 1.0 is 194 f.
I got it because I am sick to death of worrying about whether I am level enough or not.
I was not amused to have not a single scrap of documentation on the ARP. The other solution I was considering was leveling jacks which would have been a much larger expense.
Once I get the arp unit permanently installed, I may "twiddle" with the chimney fans thermostat and have it cut in at a higher number.
Regards, Don
