โFeb-09-2015 06:49 PM
โFeb-10-2015 08:45 AM
newman fulltimer wrote:
If in a hot climant running the ac its pulling alot of amprage your converter or basttery is not keeping up for the smount needed. Once the temp cools of the demand goes down voltage goes up and fridge comes on.
Check wiring connectoins for corrosion and tightness battery for proper voltage
โFeb-10-2015 07:38 AM
โFeb-10-2015 07:25 AM
โFeb-10-2015 07:17 AM
j-d wrote:
I know the sun beating on the fridge side of our coach interferes with its cooling. It's never cut off, though. I added a couple little computer fans to help the air flow over the coils and that's been enough to get satisfactory temps.
I don't believe our 12-year-old Norcold N811 has a thermal cutoff to shut down if the coils overheat. But I wonder if yours does. Maybe the additional heat load from the sun is enough to trip it if the coil temp was already toward max.
โFeb-10-2015 05:02 AM
โFeb-10-2015 04:48 AM
โFeb-10-2015 04:27 AM
dougrainer wrote:
The heat build up from the sun is minor compared to the heat generated by the LP burner. I have NEVER had or heard of a heat issue causing a Control board malfunction on a refer. When this happens again, fire up the refer on LP and immediately lite the stove top burners(all 3 or 4). See if the stove top burners either do not all light or the flame is very low. I would suspect heat causing the LP regulator to malfunction. You DO have clear unobstructed ventilation all the way up the refer roof top vent? Doug
โFeb-10-2015 04:18 AM
BFL13 wrote:
Yes a fan could help. This thread has some info. Chillin with Bob link has lots of info, some of which may apply to the OP.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27841859/srt/pa/pging/1/page/2.cfm
โFeb-10-2015 04:11 AM
โFeb-09-2015 07:30 PM
โFeb-09-2015 07:19 PM
