front door awning
hogbob
The front door awning will not retract. The motor is turning but it will not grab the gear.Thank you for any help Kenny
4 REPLIES 4
MrWizard
Moderator
Moderator
we know its powered.."motor is running not grabbing gear"
to the OP
make and model please, and perhaps year and model of RV
its likely somebody with the same RV and awning has encountered the same problem
I can explain it to you.
1997 F53 Bounder 36s
donn0128
Make, model, powered, non powered for starters.
hogbob
What do you want to know DON
donn0128
More info would be helpful
