Thetford door not closing?
backbencher
Got a new Thetford installed 4 years ago, just recently sometimes the door doesn't shut - ie, locks open. Was dumping it yesterday, and it stuck open twice. Had to put the gloves on, and reach in to flip it shut. Any easy fixes?
7 REPLIES 7
Dutch_12078
RJsfishin wrote:
Their all flat blades, possibly could be called doors ???
Anyone with a Style Plus or similar model Thetford toilet can tell you that, no, they're not all flat blades. Some models use a half ball style valve that seems to be better at self cleaning than the flat blade valves.
Dutch
2001 GBM Landau 34' Class A
Old-Biscuit
backbencher wrote:
Rgr, thanks. So, it's called a blade, instead of a door. Got it.
I'll give lubricating a shot.
Thoroughly clean bowl seal & blade first.
backbencher
RJsfishin
I only ever had trouble w/ one years ago, and it was from hard water deposits.
If its bad enuff, replace the blade, and maybe the whole turlet. I cleaned mine up as best I could, but it never would hold water very well.
If I had to do it again, I mite try some shower cleaner,....that mite dissolve that hard scale w/o damaging the plastic from scraping on it ??
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Joe417
Guys,
I think he's talking about a blade flush mechanism. They're flat.
I have and see mostly ball valve mechanisms but had a blade on my first camper. I'm pretty sure it was a Thetford toilet.
Joe and Evelyn
DutchmenSport
I'm confused too? What door?
Old-Biscuit
New Thetford WHAT? DOOR?
IF toilet.......clean the toilet bowl seal and blade.
Really clean it using your hands to flex it while cleaning.
Then lube seal and blade with plumbers grease or even olive oil. Rub it in good.
NO petroleum based grease/lube
