Furnace left on while storing TT
rexmitchell
I'm pretty sure I left my furnace in the on position in my TT this weekend and we are a two hour drive away. The gas is turned off so it won't be using gas but the battery is charged and hooked up so it has power to it. Is it just going to run when the temp gets low enough to kick it on? Will the furnace sense that there isn't any gas and cut off? I'll be back out at the RV in two week but I'm debating if I need to drive back out before then and cut it off.
Thanks, Rex
15 REPLIES 15
John_Wayne
If it's like mine it will try to light 3 times then the fan will just keep running till I turn it off at the thermostat. Mine is an Atwood.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
