Newbie to this forum, not new to RVing.
I just purchased a pop up truck camper, 1996 Skamper #080.
Need some help with the furnace. It looks rarely used. Will not fire off/lite., Hookup to house power, has an on-off switch before gas valve (turned on) Gas on and full, cracked gas fitting at valve to verify propane-yes. Turn t-stat up to 90 and a few seconds later the blower kicks on as its suppose to. 6 seconds later the double solenoids both click to ope gas valve (But does light. I can can faintly here the valve close I believe. Re-set t-stat multiply times with no luck. Going through the same procedures with a VOM, I do have 10.9 volts hitting the coils, the wire coming off the circuit board has 13 volts going to the igniter. After the few seconds the only thing running is still the fan. Which manual says it will lock out. Any pointers before taking it to a shop. I am mechanically incline so I can do any of the work myself if needed but don't want to start buying valves etc just yet.
