โFeb-01-2017 05:19 AM
โFeb-05-2017 07:51 PM
โFeb-05-2017 07:00 PM
โFeb-05-2017 06:52 PM
โFeb-05-2017 04:19 PM
Harvey51 wrote:
15 KWH/ month is half a KWh per day, so a 100 watts of solar collector could run it.
Harvey51 wrote:
I don't see any prices for these fridges.
โFeb-05-2017 02:15 PM
โFeb-05-2017 12:17 PM
The SUN FROST RF16 typically consumes 15 KWH per month. By contrast, the average refrigerator in a home consumes 75 KWH per month. Producing the 75 KWH needed to run this refrigerator in an off-grid solar power system would require an initial investment of at least $4,500 in hardware. The SUN FROST would require a $500 investment.http://www.sunfrost.com/all_efficient_refrigerator_models.html
โFeb-04-2017 09:33 AM
MrWizard wrote:
slide works , IF it is baffled correctly has fans, and NO dead air space above the fridge to trap hot air
some RV mfg, get it ride, and a it seems a lot more get it wrong
โFeb-03-2017 09:48 PM
โFeb-03-2017 09:27 PM
โFeb-03-2017 07:14 PM
โFeb-03-2017 05:23 PM
โFeb-02-2017 12:49 PM
pnichols wrote:John & Angela wrote:
Sucks though, because they all pale in comparison to compressor fridges.
How so? :h Our propane refrigerator has been pretty much flawless and reliable for 10 years.
I wonder if many RV builders haven't installed propane refrigerators really quite right? For instance, there's such things as installing them with their ventilation flue being vertical straight up and users keeping their water drain tube clear of insects and debris. I also wonder how well a propane refrigerator would do when it's installed in a slide that is not always extended?
BTW, some remote cabins have had a full size propane refrigerator in them for decades ... I stayed in one last summer and it did just fine.
As usual, quality of design and construction is everything in an RV.
โFeb-02-2017 12:24 PM
pnichols wrote:I think PNichols has a valid point. My RV's fridge is installed pretty badly according to the guidelines published in Dometic's installation manual.John & Angela wrote:
โFeb-02-2017 12:17 PM
