โJun-24-2014 09:15 AM
โJul-01-2014 07:55 PM
โJul-01-2014 02:18 PM
Lexicon7 wrote:
WestEnd.. OK now I got it, thanks.. I think for a space this small I may be overthinking it... as you say, just use the "multi-plug" extension..
โJul-01-2014 02:03 PM
โJul-01-2014 08:07 AM
โJul-01-2014 05:19 AM
Lexicon7 wrote:I was posting about using a transfer switch to power your receptacles when away from shore power. In the situation of a truck camper, it is probably more convenient (and less expensive) to just plug a multi outlet surge protector into the inverter and mount it somewhere convenient. That is how mine is now but I will be installing dedicated receptacles (a couple) that run just with the inverter. Then again, if I get an urge, I may just use the 15 amp transfer switches. It's about how clean an installation one wants and the convenience of not shifting plugs.
WestEnd ::: sorry to say, I am having difficulty following you on the "house" power / inverter issue I brought up... I like that site and have come to respect the Xantrex name...
For shear convenience, you think it would even be worth it? I suppose I could just rig a 4 place junction box on the end of a living area length extension cord... Can't wait to get out of here and start putting all this to the test. I'm sure I'll never stop tweaking stuff..
โJul-01-2014 12:53 AM
โJun-30-2014 09:43 PM
Lexicon7 wrote:
RM2510 Dometic.
โJun-30-2014 07:52 PM
โJun-30-2014 07:46 PM
โJun-30-2014 07:36 PM
โJun-30-2014 07:35 PM
โJun-30-2014 07:34 PM
โJun-30-2014 06:43 PM
Lexicon7 wrote:
... I am leaving it on gas. After further review, it seems that the "absorbtion" system uses electricity.
If this is true it must be on the house circuit. Either way, if the cheesy little Lance issue "colored light array" system has any credence, my batt is full and I've never seen it any other way!
โJun-30-2014 06:15 PM
