โFeb-16-2016 11:46 AM
โFeb-16-2016 04:47 PM
Huntindog wrote:
When comparing inverter generators, one thing to look at is that not all of them are parallel capable.. That means pairing two of them for twice the power. That will run anything you want in a 30 amp TT. It is something that may not seem important today,,, as just getting some power will seem like a luxury... But down the road you may want more.
The Champions you are looking at can be twined. The Generacs,,, I don't think so. All of the Hondas can be. Some of the Yamahas can be.
โFeb-16-2016 04:31 PM
Almot wrote:
There isn't much need to buy 2000W generator and pair it with already existing 2000W, if A/C will not be used.
The biggest load (after the A/C) is microwave ~1200-1500W. As long as they don't try running it at the same time with a 1000W coffee maker, they are OK. Some coffee makers can draw close to 2000W.
All other loads, be it 120V or 12V, are negligible in comparison, you can run them off the pair of batteries with inverter.
โFeb-16-2016 04:10 PM
โFeb-16-2016 04:09 PM
โFeb-16-2016 03:34 PM
โFeb-16-2016 03:00 PM
โFeb-16-2016 02:09 PM
Cougarnewbie wrote:
Curious if it is good enough? I understand no A.C.. My cougar is 30 amp hook up. With adapter will it run my PD converter?....Hey moderator, we need forum to compare common products without violating the buy and sell policy.
โFeb-16-2016 12:49 PM
โFeb-16-2016 12:22 PM
โFeb-16-2016 12:18 PM
