Generator fuel pump
KnowNuthin
I have an Onan 4000 GenSet...
There is a white wire that supplies 12 V to the electric fuel pump… Right now I'm getting approximately 6 to 7 V out of that wire… Not enough to run the fuel pump… In another post I raise the question regarding my battery isolator and possibly corroded battery connections…
Can I just run a hot wire to the fuel pump installing a switch so I can shut it off or is that white wire automatically switched to turn the fuel pump on and off as needed as the float bowl fills and empties ?
2005 2500HD D/A CC LB 4X4 being pushed by:
2016 Grand Design Reflection 303RLS
2007 Ural GearUp Arctic
6 REPLIES 6
KnowNuthin
I putzed with the cables a bit last night... didn't have time to loosen/clean/tighten everything but I did wiggle all the connections I could get to and the genny gave some sign of life....
I think we're on to something here....
This weekend I'll replace the isolator (obviously rusted in places) and clean all the connections I can find... and keep my fingers crossed
midnightsadie
X2 ground wire does strange things.
1492
Moderator
Moderator
Moved from Technology Corner
ksg5000
Check/Clean all the battery terminal as well as the grounds (both vehicle and generator) - that should eliminate some of the obvious low voltage issues. Then start the engine which should put chassis/coach batteries "online" and try and start the generator.
Kevin
Ivylog
Most electric fuel pump shut off automatically when the pressure is high enough. As a temporary fix I would run the wire but you do need to find the real problem.
Upgraded with a 08 HR Navigator 45’...
azrving
I would find the problem. Doing that will only make it less safe.
