Generator starts but stalls - SOLVED
HackerAce
My Generac on the 1999 National Tropical would start and run for about five minutes before shutting down. It would then start right back up, run for five minutes, and shutdown.
Replaced the fuel filter ($5.00), did not fix it.
Replaced the fuel pump ($80.00), did not fix it.
Disconnected the wires to the low oil sensor, that fixed it!
Replaced the low oil sensor ($22.00), problem solved.
My advice for anyone in my shoes would be to disconnect the low oil sensor (make sure you have oil first ๐Ÿ™‚ and see if that fixes the problem. Would have saved me $82.00. Of course a 17 year old MH probably needed a new fuel filter and pump anyway. ๐Ÿ˜‰
John McKean
1965 Shelby Cobra Factory Five MK III Kit
2015 Hyundai Genesis
2013 Polaris RZR 800 S
3 REPLIES 3
ddndoug
fla-gypsy wrote:
Thanks for reporting the fix
X2
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
fla-gypsy
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
gbopp
The fuel filter and pump were definitely not a waste of money.
Did you keep the old pump for a spare?
