โMar-12-2018 01:37 PM
โMar-12-2018 05:56 PM
โMar-12-2018 05:51 PM
โMar-12-2018 05:33 PM
โMar-12-2018 05:08 PM
filrupmark wrote:
To bad carburetors don't have main jet adjustment screws anymore.
morphrider wrote:
I have a champion generator and did call to get the jet. But in discussions with the tech he stated that it just would make it run a little smoother at elevation but it will not produce any more power. We are usually at 9000' and I did not swap the jets. It runs good as is so I have the jet shoved in a drawer somewhere. What elevation are you staying at?
โMar-12-2018 05:05 PM
โMar-12-2018 04:58 PM
Chum lee wrote:
Running your generator at higher altitudes with the sea level jetting will cause it to run rich. It may smoke a little, maybe not. It will use more fuel than necessary and it may foul the spark plug and/or dilute the engine oil with fuel. Running it at sea level with the high altitude jet will cause it to run lean. You may experience loss of power, hard starting/rough running, or excessive engine temps.
Time will tell how it effects longevity. Your choice.
Chum lee
โMar-12-2018 04:25 PM
โMar-12-2018 04:14 PM
โMar-12-2018 03:22 PM
โMar-12-2018 03:19 PM
โMar-12-2018 02:45 PM
โMar-12-2018 02:20 PM
โMar-12-2018 02:18 PM
Colo Native wrote:
I have my Champion generator and did the break in, now I put the high altitude(3500'or higher) and I must say it was a PITA how many people leave it in or don't use it because it is a PITA. I would say about half the time I would be at altitude so Is it really needed?
