โJul-30-2019 05:29 AM
โAug-07-2019 09:43 AM
โAug-02-2019 08:42 AM
road-runner wrote:
This is a weird situation and I doubt that there will be much if any actual experience to draw from. Only best guesses. The GFI senses only downstream faults, so I don't see how doing anything at the generator or transfer switch would fix the problem. The power out of the generator isn't as clean as shore power, which could explain why you never see the trip on shore power. When there are weird GFI trips I'm usually about the last person to say "replace the GFI", but in this case I don't think that's a bad thing to try. Another obvious isolation step is to disconnect the downstream outlets from the GFI. Tough call, in my estimation, which to try first.
โAug-02-2019 01:29 AM
3 tons wrote:
Op, disappeared....
โAug-01-2019 04:22 PM
โJul-30-2019 11:40 AM
โJul-30-2019 11:20 AM
โJul-30-2019 10:07 AM
โJul-30-2019 08:52 AM
PNW_Steve wrote:
I can't get the link to work. Copy and paste the address into your browser.
โJul-30-2019 08:48 AM
โJul-30-2019 08:25 AM
โJul-30-2019 08:22 AM
โJul-30-2019 06:55 AM
