โApr-08-2014 08:45 AM
โApr-09-2014 06:33 PM
BFL13 wrote:X2 BFL is most correct.
IMO you are not in the clear yet. The converter in a 2001 rig is likely one that should be doing 13.6 or so. Outside chance it is a 9100 and can do 13.2 but not until it has sat for a while at 13.6.
Find the battery lugs on the DC fuse panel inside the rig and take the converter voltage there. Should be 13.6. Then at the battery should be almost 13.6 with a full battery.
If still 13.1 suspect corrosion at connections--especially that battery neg ground wire at the frame.
You might want a better converter to look after your new battery, but IMO first get the wiring etc for this one cleaned up and working right. On that, be sure your new fuse/circuit breaker can handle say 60amps for any new converter you might get in future. That original corroded one may be too low in amps for that.
โApr-09-2014 05:08 PM
โApr-09-2014 04:57 PM
Unyalli wrote:Kiwi_too wrote:
Sorry, but I would not get the above for this diagnosis. It is good at showing what is going through that socket. There is value to that. To run down a problem, you want a 120/12v volt meter with probes, so you can test all lines and components. You cannot test the relay with the above.
Disagree, for a few bucks it's far better the 4 leds.
โApr-09-2014 04:22 PM
โApr-09-2014 01:09 PM
โApr-09-2014 12:32 PM
โApr-09-2014 11:36 AM
โApr-09-2014 09:17 AM
โApr-09-2014 09:04 AM
โApr-09-2014 08:42 AM
โApr-09-2014 08:38 AM
โApr-09-2014 08:30 AM
โApr-09-2014 08:24 AM
โApr-09-2014 07:47 AM
