Feb-10-2017 03:51 AM
2014 F-350 SRW CC/LWB 4X4 6.7PSD
Feb-28-2017 09:40 AM
red31 wrote:
vent pointed down, leaking valves need fixin
Feb-25-2017 02:40 PM
Feb-25-2017 05:25 AM
Feb-25-2017 04:27 AM
Feb-19-2017 11:35 AM
Feb-19-2017 07:28 AM
Sam Spade wrote:
It is not unusual to have some smell outside when first turned ON. The valve stems don't seal perfectly; you need to turn it all the way on to seal the handle.
Feb-19-2017 04:30 AM
Feb-18-2017 09:36 PM
Feb-18-2017 04:31 AM
Feb-17-2017 03:25 PM
Feb-17-2017 05:38 AM
Feb-14-2017 05:57 AM
BB_TX wrote:
Do you have a high pressure propane regulator valve, often referred to as the little red regulator valve, near one of your tanks? (Not the two stage change over regulator valve) Those little high pressure regulator valves are notorious for leaking. Inexpensive and easy to replace.
I could smell propane in my driver's side propane tank compartment a number of years ago. Using soapy water and then leak detector fluid, I could not find any bubbles any where. After much searching and reading RV forums, I replaced the high pressure regulator valve and no more odor. When I removed the old one, I could see an oily like substance around the vent hole on the bottom of the regulator. Apparently it was leaking, but the soapy water was not getting to that hole on the bottom and therefore no bubbles.
Feb-10-2017 02:32 PM
Mortimer Brewster wrote:
So what I'm hearing here is that if your spouse complains about a gas smell, you should blame it on the the regulator?
Feb-10-2017 12:52 PM
