โJul-27-2013 05:07 AM
โAug-03-2013 04:24 AM
โAug-02-2013 06:55 PM
Snowman9000 wrote:You can but you'll have to babysit it. Follow MEX's steps but if you're not using a converter first then MEX's route will take longer.
I was hoping to use the HF for charging from 50 to 90%, instead of my built in 7345. But it looks like it's more suited for going from 80 or 90 to 100%. Please correct me if I'm wrong.
โAug-02-2013 05:07 PM
โAug-01-2013 08:19 PM
MEXICOWANDERER wrote:I got almost 19 from mine. I figured it was because of the size bank I was using. Will it do that on smaller banks too?
18 amps out of a 10 amp charger for that kind of money is tough to beat.
โAug-01-2013 01:05 PM
โJul-27-2013 04:33 PM
Snowman9000 wrote:
Clearly I have a lot to learn. (sigh)
๐
I thought it should push whatever amps it does at high voltage right away, like my B&D charger does. I'll have to test my Battery Tender too. I am under the impression it start out in the mid 14's.
โJul-27-2013 12:26 PM
red31 wrote:This correct, the Start mode is for manual use with this charger. Most of us with this charger are only using it to do equalizations and finishing charges. You CAN use it to charge the batteries but like was mentioned, the amps are low so it will take a long time to do that. Also, you need to keep an eye on it to make sure it does not overcharge your batteries. But at 10 amps, it will take a number of HOURS to do so. MEX does not trust the auto charging function of this charger but the manual portion works just fine.
I thought the MEX HF charger was for doing a periodic overcharge to 15.0 v after charging or slight self discharge.
I was planning on trying this with a ole 'diehard' 6/2 amp before building the timer switch that would let me turn it on to X hrs and walk away.
โJul-27-2013 08:09 AM
โJul-27-2013 06:56 AM
Porsche or Country Coach!
โJul-27-2013 06:34 AM
โJul-27-2013 06:27 AM
