โNov-05-2016 08:06 AM
โNov-06-2016 09:53 AM
โNov-06-2016 07:40 AM
Matt_Colie wrote:Jim-Linda wrote:
Single lamp each side, kit has housing that replaces sealed beam, H4 lamp, rubber cover for the original connector. Original connector and contact on H4 are the same, low beam works,
Jim
Jim,
This is interesting as the H4 lamp is the same connector as the 6012 you removed. I have run into cases where there were features of the OE connector that did not work with the composite headlamp assembly, but those were usually very obvious.
Matt
โNov-06-2016 06:32 AM
Jim
โNov-06-2016 06:31 AM
โNov-06-2016 06:30 AM
Sam Spade wrote:SCVJeff wrote:
The only non-sealed lamps I am aware of are Hella and Cibe.
I was under the impression that ALL halogen lights had replaceable bulbs that come out the back; thus not sealed.
โNov-06-2016 04:49 AM
โNov-05-2016 09:26 PM
โNov-05-2016 08:44 PM
โNov-05-2016 06:29 PM
โNov-05-2016 05:57 PM
โNov-05-2016 03:57 PM
โNov-05-2016 02:17 PM
โNov-05-2016 01:20 PM
โNov-05-2016 10:29 AM
