โJun-01-2015 01:01 PM
โJun-01-2015 10:52 PM
dougrainer wrote:
1. The recall has NOTHING to do with how well the 1200 cools(unless he does something wrong-- seem item 4).
2. IF the dealer has NOT looked at it in person, then he should NOT be quoting any parts/labor.
3. From your description, the FIRST thing to verify is IF the rear cooling unit fans are running. If they are not operating what you have experienced is what will happen. Most common failure is the fan tstat that causes the fans to not operate.
4. Depending on the specific model 1200, they may have reversed the fan control wires on the rear control board which will render those fans INOP. I have fixed at least a dozen 1200 recall refers that the Technician reversed those wires and caused inadequate cooling. The refers worked pretty well in sub 70 degree temps but when it got hotter, the refer needed those fans to keep it cool. Doug
โJun-01-2015 07:12 PM
JnJnKatiebug wrote:Had a similar experience a couple of years ago. Fridge DID cool ok while running on AC but not gas. Long story short, after all the usual cleaning of burner and jet I found my LP regulator pressure had dropped from 11 inches WC to 8 inches WC so the gas flame was too low to cool properly. New regulator solved the problem. Does it cool properly on shore power?
.... On our last trip we bought a temp gauge and put inside. It was about 45 degrees which I know is too warm. On the way home it pretty much quick working and was showing 55 degrees when we arrived home. The freezer is still working fine and everything in it was still hard frozen....
Reese Dual Cam Straight Line HP Sway Control
โJun-01-2015 03:49 PM
โJun-01-2015 03:42 PM
Dakota98 wrote:louiskathy wrote:
In case you are thinking of replacing a cooling unit and doing the work yourself... know what you are getting in to.
Our cooling unit replacement in pictures.
YIKES !!!
That's the unit I have -- :E
โJun-01-2015 03:14 PM
โJun-01-2015 02:47 PM
โJun-01-2015 02:10 PM
โJun-01-2015 01:33 PM
โJun-01-2015 01:28 PM
โJun-01-2015 01:20 PM
