Help!! No Battery Power to 2014 coleman 192 rd
ahiaring
I bought this model new from CW last year and had an issue with a bad breaker on the frame near the box...It would not transfer battery power to the unit. I could only run a few items if I was plugged in. I took it in and they replaced the breaker on the frame where the battery cables come in. I was told that if this happens there should be a button to push or reset the breaker? I have struck out and have no power at all to the unit. Can someone share some light on how to address this or a pic/video of how to reset this?
2 REPLIES 2
bikendan
look for something, like this, along the A-frame of the trailer:
usually tucked inside where you can't see it.
press the black button on the side.
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Mandalay_Parr
Are you sure your battery is good?
I would check that with a meter first.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
