โMay-02-2016 03:58 PM
โMay-04-2016 11:31 AM
โMay-04-2016 08:15 AM
โMay-04-2016 07:32 AM
bondj007 wrote:
Hmmm - Good point, however the one thing that confuses me is the pump pressurizing delay also happens when just running cold water - ie nothing should be coming from hw tank but still takes 5 secs to pressure up when hw tank bypass is off. Why would this be?
โMay-03-2016 08:23 PM
โMay-03-2016 05:53 PM
โMay-03-2016 04:26 PM
bondj007 wrote:
OEM was shurflo 2088-422-144 - 30 psi inlet, 45 shut off vs 55 for the 4008 as you mention. I've done a little trial and error on setting the pressure switch so not sure where it sits at the moment. What would be the consequence of going to a higher rated pump?
โMay-03-2016 01:35 PM
โMay-03-2016 12:49 PM
โMay-03-2016 12:40 PM
โMay-03-2016 12:14 PM
โMay-03-2016 10:46 AM
bondj007 wrote:
Well, not sure to feel relieved or dumb that things are working as intended. I'm at work so am unable to verify however I suspect that the leaky strainer will resolve the water hammer issues I've been experiencing.
I am experiencing some of the accumulator behaviour that you guys speak of however I just don't recall this being the case in prior years. WHen I turn on the tap it's a good 2 secs before pump kicks in and a good 3-5 to shut off after tap close. All seems new to me however if it's working as designed, I'll try and let it go and go back to worrying about more important things. One more post later tonight to confirm water hammer gone and that may be the end of the thread. Thanks for all that chimed in to help me sort - greatly appreciated.
โMay-03-2016 10:00 AM
โMay-03-2016 08:56 AM
Chris Bryant wrote:
The water heater acts as an accumulator in the system, whether you run the hot water or not. It is working the way it is supposed to- if there were no air cushion, the system pressure would rise enough to trip the PTR valve on the water heater every time you heated water.
โMay-03-2016 08:45 AM
