Help with Dometic Digital Thermostat
D_E_Bishop
We're somewhat isolated here at the beach with very slow internet and our Cousin is having trouble with her furnace. She has a two year old rig and the heater won't come on. I found that the Dometic TS #3313189.023 is a three wire and I know from nothing about them. I know where the control panel is and thought I could check the output to the furnace for twelve volts but after that I'm lost if there is no 12 volt out put. She really doesn't want to drive home and have it fixed so I thought I'd check if it's the furnace or the thermostat/control panel.
Is there some way to check if the Furnace feature of the TS is working? All the other functions work. I thought I'd reinitialize the control panel today but other than that is there anything I can check in the TS system. I've verified that there is power to the furnace. I just have my little Fluke DMM so it's just a basic DMM.
If the furnace is getting 12 volts, I can troubleshoot that but not the electronics of the TS.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
0 REPLIES 0
