โMar-22-2022 01:59 PM
โMar-26-2022 09:58 AM
โMar-25-2022 10:01 AM
โMar-24-2022 03:48 PM
โMar-24-2022 02:08 PM
โMar-24-2022 01:37 PM
dapperdan wrote:
MC, Iโm not sure whatโs changed since my โ15 RAM but my truck didnโt come with a fuel cap either, just a โflipperโ style closure. When I first installed the RDS in my โ06 RAM I DID have a fuel cap. My installation into the โ15 was similar to the โ06. Under the truck up in the fender I cut the metal filler tube, spliced in the โTโ with the rubber boots included in the RDS kit. Supposedly thereโs a check valve setup to prevent over flow. Iโve never had an issue with fuel spills!
I run the truck tank below half of more then flip the valve on the RDS tank and let the fuel from the RDS gravity flow into the truck tank. It looks โweirdโ to be running down the road and have the fuel gauge start climbing! LOL The install is fairly easy and having the extra fuel capacity is great!!
Dan
โMar-24-2022 11:41 AM
โMar-24-2022 08:34 AM
dapperdan wrote:
So you already have an RDS tank, why not contact RDS customer service and inquire as to how to hook up your transfer tank? They're awesome people and I'm sure they can give you a much simpler answer!
I have a 2015 3500 with an RDS transfer tank mounted in the bed, it wasn't at all difficult to install, including the "RDS install kit" which is basically a "T" and some tubing! It's really pretty simple and straight forward.
Call RDS, ask how to go about installing the tank in your new 2022 RAM, I'm sure they'll have an answer for ya!
Mine's worked GREAT for over 10 years now! Good luck moving forward.
Dan
โMar-24-2022 05:03 AM
โMar-23-2022 11:42 AM
2112 wrote:
How about installing a manual bypass valve bypassing the solenoid valve in case the solenoid fails? You can have both.
Do they make a fuel grade latching solenoid valve?
โMar-23-2022 11:25 AM
โMar-23-2022 10:23 AM
Grit dog wrote:
Not sure if youโre missing anything. Since youโre now considering the check valve kit.
But Iโm missing why youโd want to introduce yet a 3rd way to โstopโ the fuel. (The electric valve)
โMar-23-2022 09:58 AM
โMar-23-2022 09:07 AM
โMar-23-2022 08:51 AM
